跳转到主内容
加入维修社区 - 创建账户
Repair guides, disassembly, and troubleshooting information for HP EliteBook 840 Series business laptops.
Laptop won't boot up after RAM upgrade - HP EliteBook 840 G8
Hi there,
After replacing the original 32GB in my HP EliteBook 840 G8 with a Crucial DDR4-3200 64 GB kit my laptop turns on, but the screen remains black for about 10 seconds before fan starts overworking, after which I can only shut down the thing before it takes off, by pressing and holding the power button. While the screen is black but the fan is still silent, Capslock is blinking for 5 times (white). The laptop has no problems doing it's thing with the original kit.
I've looked for possible fixes and found this article, but unfortunately none of the steps helped:
https://h30434.www3.hp.com/t5/Notebook-B....
As per this HP article the new kit should be compatible:
https://support.hp.com/gb-en/document/c0...
I'm quite new to HPs so unsure of where to start; thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I just got the same issue, have you ever found a solution?
完成的
HP Elitebook 860 G9 i5. I upgraded from 16 to 32GB DDR5. Laptop screen was black, keyboard lights and ventilator winds. But nothing ... How I fixed it:
Hold Win + B and then press power button for a second, then release all keys. Now just leave the laptop aside and wait ... the process takes around a minute. The ventilator will start to work intensively. After a while it will shut down and start again in with the same process ... and then you'll see the logo and then a message that the system was updated with the hardware ... Just needs time.
完成的
添加一条评论
3个答案
已选择的解决方案
Hi, upgrading to the latest BIOS fixed it
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hold Win + B and then press power button for a SECOND, then release all keys. Now just leave the laptop aside and wait ... the process takes around a minute. The ventilator will start to work intensively. After a while it will shut down and start again in with the same process ... and then you'll see the logo and then a message that the system was updated with the hardware ... Just needs time.
I upgraded my BIOS too, but it didn't help. So first the try solution from above. If it does not help update BIOS and try once again Win + B and power button
这个答案有帮助吗?
得分 4
3条评论:
Thanks, Kiril. The laptop was not starting since more than an hour, but with this it really worked. Plus plus for this trick!!!
完成的
Win + b worked perfectly, thank you!!
完成的
I had 8 Gig DDR4 in Slot 2 of my HP 840 G8, I added another 8 GIG of the same configuration (3200MHZ) in Slot 1 but it was not detecting. I was clueless on what was happening because the RAM was new and I thought may by my Slot 1 is KAPUT but then this post helped. Did WIN + B + POWER and it accepted my new ram and my laptop now works on 16 GIG.. Big Thanks to you!!!
完成的
添加一条评论
Hi @ritahegedus,
Have you tried using just one 32GB memory module at a time, in case it is a faulty module?
Try a power refresh (aka BIOS reset) and check if that works.
Here's the procedure:
Disconnect the charger if connected and turn off laptop if on, open the laptop and disconnect the main battery from the motherboard. (you don't have to remove it, just disconnect it).
Disconnect the RTC coin cell battery from the motherboard
Here's the maintenance and service guide for the laptop. Go to p.43 and p.45 to view how to remove the battery and RTC battery respectively.
Press and hold the laptop's Power on button for a full 30 seconds and then release.
Reverse the above steps to reassemble the laptop and check what happens what you try to start it.
If it starts OK there may be a message regarding the date and time being incorrect. This is normal as the BIOS has been reset. Once the D&T have been adjusted, the message won't appear the next time the laptop is started.
Have you checked that the latest BIOS version is installed? Seems like a lot of problems have been addressed since BIOS version 01.07.02 Rev.A was released in Dec '21
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rita Hegedus 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 118
总计 3,822
