跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
iPod Classic no response
My friend gave me an iPod classic he didn't use anymore. when I plugged it in, It started to bootloop like crazy. I left it plugged in for a while and let it do its thing, hoping it would turn on. I unplugged it and plugged it back in and suddenly I'm getting absolutely no response from the iPod. No charging screen, no bootlooping, I can't even hear the hard drive spinning (which I could before and it sounded like any old hard drive should). I've been wanting a classic for years and now that I have one I'm really hoping I can fix it without opening it up. Has this happened to anyone else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
Chances are you battery has failed
Heres a replacement guide
iPod Classic电池更换
Heres a replacement part
Thick battery
iPod Classic (Thick) Battery
Thin battery
iPod Classic (Thin) Battery
depending on the iPod storage and thickness you might need to get ether if these batterys
Hopefully this helps
Any questions please ask
iPod Classic (Thin) Battery图片
产品
$13.99
iPod Classic (Thick) Battery图片
产品
$14.99
这个答案有帮助吗?
得分 1
2条评论:
But if the battery was bad would it even try to turn on and bootloop? It was doing that for probably a good 15 minutes until I unplugged it. I did notice that it died immediately when it was unplugged.
完成的
@lemaxstudios
Yes it will even do that if it has a bad battery:-)
Iv seen this a couples times across various devices and 9/10 this fixed it:-)
完成的
添加一条评论
添加你的答案
Lemax Studios 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 35
