跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1051 个问题 查看全部
I have a non-tappable stripe on my screen
After changing the battery, I now have a barely-visible stripe down the middle (about one fourth from the left), 1 millimetre wide. I can't tap anywhere on that stripe, so for example I can't type the letter E. I also can't turn off the device because I can't "grab" the slider.
I've tried taking the phone apart again and making sure all the connectors are in place.
Help! I don't want to get rid of this device, especially since I JUST changed the battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hmm unfortunately it may sound like the screen was damaged in the process. The fortunate part is that they are pretty cheap and easily installable from some third party companies. When you say stripe is it like a bright line? A pixel or two wide? If that’s the case then definitely LCD or digitizer damage. Last suggestion is to clean the connectors lightly with alcohol if the screen is physically ok as I stated above(no visible lines or cracks). If this doesn’t work then a new screen should fix the issue. Best of luck!
这个答案有帮助吗?
得分 2
6条评论:
More like 10 or 20 pixels, but it's hardly visible, and only sometimes. Does that still sound like screen damage?
完成的
@ovesh Yes I’d still say screen damage. You could mess with it more and see what causes it to be intermittent but I’m banking on screen damage. Also make sure the plates(covers over the cables) are put back correctly and secured when testing further.
完成的
I have an old iPhone SE laying around. I think I'd like to try and see if I can grab the screen from there and replacing it. If I do it without replacing the home button assembly, would the phone as a whole still function? If only for verification to see if it fixes it. If I understand correctly, the only thing that wouldn't work is touch ID, is that correct?
完成的
Yeah you’re correct! If you swap the home button into the new (other) screen it’ll function the same as it was before with Touch ID and everything. But for testing purposes it is not needed and will function as a home button but no Touch ID.
完成的
I changed the screen... and I still have the exact same problem. So at least I've ruled out that it's a problem with the screen. What else can it be?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Avishai Weissberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 47
