跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
My door ajar light stays on when all doors are completely shut.
Door ajar light stays on
Update (03/16/23)
It is a astra 2005
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @kent29659
What is the year and model of the vehicle?
Sounds like one of the door switches (located in the door jamb of the doors) is faulty. Either the switch contact is not opening when the door is shut or the switch is corroded and there is a permanent earth signal on the signal lead back to the body control module or the instrument panel (depends on model and year).
There are plenty of videos on YouTube that show how to check if the door switch is OK
Update (03/16/23)
Hi @kent29659
Couldn't find a video for your exact vehicle, but here's a video that shows what to look for. The principle of operation for the door ajar light is the same for most vehicles. What can differ is the location of the switch and its design etc.
This is what the switch looks like for your model. (supplier example only, there are others online that may suit you better). The trick is to find out which one of the 4 (one for each door) is the problem and hopefully it is not a wiring problem
这个答案有帮助吗?
得分 2
1条评论:
I had the same issue. I changed the driver side door lock actuator and the problem still existed. I decided to look at the wiring in the door harness. Once I accessed the wires in the door harness, I noticed a pink/white wire has completely frayed and another wire exposed. I purchased 16 gauge wire and re-connected the wires. Problem solved! I believe the wires in the door harness don’t allow for much play and get worn over time with the opening and closing of the door.
完成的
添加一条评论
My car it a 2003 cad CTS l fix most every thing but can't fix this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kent 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 47
过去 30 天: 241
总计 20,834
