跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
MacBook Pro Will Not Charge or Turn On
I have a MacBook Pro that had a charging adapter that started sparking, so I ordered a replacement adapter.
When I received the adapter and plugged it in, the screen of the Mac showed a discharged battery with a charging lightning bolt under it.
I left it charging for an hour then tried to start up the machine and it still showed the same icon. I then tried a different charging adapter with the same result.
It was suggested to me to replace the power port in the computer as it may have been damaged by the sparking adapter. I ordered a replacement board and installed it in the MacBook Pro.
I reassembled the computer making sure to replace all the connectors and screws. I plugged in the adapter to the new charging port and it went green, then orange. I pressed the power button but nothing happened (the screen did not even light.
I did a SMC reset and even tried starting up with the battery disconnected from the motherboard. No luck. What can I try to do to see if the motherboard is OK or if the computer is worth replacing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the system was working before you took it apart it’s a strong likelihood something didn’t get installed correctly when you reassembled things.
I would go back and review your cable connections make sure the latches on the ZIF ribbon cable connectors are in the correct state and the ribbon cables are fully inserted. Reference this guide MacBook Pro 15‘’Retina显示器2015年中期主板交换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Biddix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 27
