跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1051 个问题 查看全部
iPhone kills any battery I connect to it
Hi,
My iPhone SE was out of charge (showing the connect charger symbol).
When I plugged it it turned on, then the screen went off. I thought it was the timeout.
After a while I came back and noticed the phone was not responding (screen does not turn on).
I thought it could be the battery, so I measured it. It was at 0V, which is weird because it was charging.
Anyway, I had a few old batteries that were still measuring over 3.8V.
When I put them, nothing happens and after I take them out, they also read 0V.
My guess is that there's a short circuit, which is also triggering battery overcurrent fuses and so any battery I put gets killed.
Does this rings a bell to anyone ?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
It sounds like you are on the right tracks about it being a short circuit as that’s what it’s most likely to be
It could be a verity of components so I would start by checking out what the components look like around the battery connection
I would look for anything burned ,discoloured or anything that looks wierd
I would also feel the board for heat
You might need to check some power rails to get to your culprit but if it’s killing battery’s it might be easy to find through heat spots (no promises though)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jean 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 25
