跳转到主内容
Apple 公司 2022 年旗舰系列的顶级产品。iPhone 14 Pro Max 于 9 月 16 日发布,配备了 6.7 英寸 ProMotion OLED、全新 Bionic A16 芯片、三重后置摄像头系统和 5G 网络,是 iPhone 13 Pro Max 的继任者。
27 个问题 查看全部
Restoration of True Tone after screen replacement (iPhone 14 Pro Max)
Got a new iPhone 14 PM about 4 months ago and yesterday it tried to jump to its death. Wound up with a shattered screen and dead digitizer. After screen replacement, I'd love to restore True Tone. Does anyone know if there exists a method like " How To Restore True Tone After Screen Replacement On iPhone XS " that works for the 14 Pro Max? Looked all through the different programmers out there and can't find any that specify compatibility with the 14 PM for restoration of True Tone. If anyone has any leads or info I sure would appreciate it. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
I've got the Qian Li iCopy 2.2 and unfortunately I can't find any support for anything later than the 11 Pro Max on the screen. The battery has support through the 13 Pro Max, but stops there.
Hate to say it, but doesn't look like the iCopy is going to help. Maybe the JC V1S has something...
这个答案有帮助吗?
得分 2
添加一条评论
As far as I am aware, there are no programmers yet which support the iPhone 14 series. This is bound to change at some point. But for the time being, the only way to restore True Tone would be to transfer the chips which store this data from the old screen to the new screen.
Transferring these components is not something most folks have the skills to do. But it can be done. It requires the ability to solder BGA chips in a temperature sensitive environment (too much heat and you damage the display). Other than that, you’ll need to wait for a programmer, or take it to Apple to get your True Tone back.
这个答案有帮助吗?
得分 1
添加一条评论
You'd need the old screen and to find a shop with the very latest programming tool.
这个答案有帮助吗?
得分 0
添加一条评论
Currently, after replacing the screen of iPhone series 13 and series 14, there is no option to copy truetone except for genuine screen replacement from Apple.
However, now there is a type of screen that seems to be a genuine apple screen, when replacing, you don't need to put the old screen IC but just install a new screen and run it again, then there will be a message "genuine parts" same as in apple store but cost more than external monitor.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue. My screen fell on the road, it got shattered, and I replaced it at a 3rd party repair shop. The replacement screen I got from him is a genuine iPhone 14 Pro Max screen. After replacing the screen, everything works perfectly except for TruTone and automatic brightness. Both stopped functioning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lost 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 61
过去 30 天: 261
总计 4,311
