跳转到主内容
Fourth generation Samsung Android tablets. Released in April 2014.
20 个问题 查看全部
Tablet charger port broke I dont want to buy the charging port
my tablets charcging port broke badly i removed charging port from th flexible wire and tried to charge the battery by opening the back cover and charging it directly,The battery is full but when i power on no response i hold the power button and volume then also no response not even vibration,I even checked all the thin flexible wires that they are connect or not, found every single wire is connected properly its like dead so........can anyone say whats the problem??????????????????????????????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When you say the charging port, do you mean the actual port in the device or the charging cable?
How did you charge the battery directly?
这个答案有帮助吗?
得分 1
7条评论:
not charging cable
thanks for reply
完成的
the charging port i am talking about
flexible wire means the thin wire it flexible and golden colour
完成的
Great, thank you. How did you charge the battery directly? What did you do to charge it?
完成的
directly.I cut the charging cable and
took positive and negetive and charged it i saw a youtube totorial
完成的
Can you say why it's not turning on
完成的
显示更多的2条评论
添加一条评论
添加你的答案
zolocoster17 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 98
