跳转到主内容
加入维修社区 - 创建账户
The Lenovo IdeaPad 3 15IIL05 is a mid-range laptop designed for general computing tasks.
Spilled Pom juice. Doesn’t always turn on.
This happened exactly a week ago:
In a rush to work I placed my laptop in the same bag as my breakfast containing Pom juice. I can’t remember which direction it was facing. I’m not sure if it spilled directly into the vents on the back or the vents sat in a puddle, but juice was dripping out when I held it sideways. It was still working at first, then not later the same afternoon. Next day it turned on and worked fine up until today, now it won’t turn on again.
As someone that’s never taken apart a computer before, is there something I can do or will I need to pay someone else to do it? If I knew what needed to be done I’d definitely try!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
the first good attempt will be take the back cover of your laptop, unplug the battery connector. examine if there is any corrosion or some obvious liquid damage trace on your motherboard and if you found one, clean it with isoprophyl alcohol 99%
If the motherboard is not get any short circuit, it should working again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lefty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 168
