Ipad 4 Irregular Voltages and 0 amp draw
Hi, any suggestion is highly appreciated because I'm in a state of depression rn thankyou :D.
Disclaimer, I usually do a laptop repairs so mobile repair is not my specialty, sorry if my approach you found somewhat dumb.
the ipad comes with no display problem with 0 amp current draw, upon checking i found the voltages around the board (when the power button is pressed) is pulsing like 3v and goes back to 0v and so on.
this symptom is look like the ipad itself is trying to boot but failed, then i began to search if there is a short circuit across the board, alas there is no short at all and all voltages look like present and healthy except for the pulsing issue.
*the pulsing issue persists when the ipad is only powered by the battery. (with and without the power cable attached)
because i have no idea where to start diagnose further, i read in many forums that U2 tristar is likely to be the culprit, with that idea I tried to replace the tristar with a new one and the problem is of course still persist.
what i have already checked are
- the battery is known good
- charging port no problem (tried another one)
* no short circuit
- power button is good i think (i've tried jumper it from the on off from the power button connector and the problem still the same)
i think the real culprit will be U8100 which is the PMU because the PMU is responsible for power delivery to those component on the logicboard (right?) but im not sure because i don't have enough evidence yet to replace that PMU
or maybe the communications board (where the baseband chip located i suppose) can cause the issue?
6条评论
How do you know the battery is good? First thing I'd try is a new battery. If it's already had one I'd remove the motherboard and check for pin damage on the battery connector. Pin damage can cause problems with the board not understanding the battery levels etc.
由 [deleted] 完成的
@strongbow i've tried with another known good battery (taken from a working ipad) and the problem still persist, the pin looks good, by the way the voltage coming from battery is stable and healthy (only the standby voltage before power button is pressed), but just when the power button is pressed the voltage become pulsing like that so from that thought process i think the battery will not be causing the issue. thankyou for your respond do you perhaps have another idea?
由 Zidny Yasrah 完成的
@zidnyyasrah I'd still be inclined to try a new battery as its a 11 year old ipad now. More so if it still has the apple battery fitted. Might be showing good voltage but might lack the amperage to power it.
由 [deleted] 完成的
@strongbow make sense, but actually yesterday i've brought a new battery out of curiosity and unfortunately the problem still persist,
also i've been injecting some voltage from the battery connector before, and the amperage is not increasing at all, the logic board didn't take any ampere.
beside the ipad is 11 year old, the customer said that he really need his data in this ipad its like super important company data or something idk. that is why i really want to fix this thing,
do you have any other idea in mind that i can try?
由 Zidny Yasrah 完成的
Have you tried something as simple as a hard reset with the charger connected? Sounds simple but you can only try. Press and hold both power and home buttons for 20 to 30 seconds and see if the apple logo appears.
由 [deleted] 完成的
显示更多的1条评论
