跳转到主内容
第二代 Sony PlayStation 5 DualSense 手把的維修指南、拆解說明與故障排除資訊。 可透過型號 CFI-ZCT1W 及主機板型號 BDM-020 進行識別。
right trigger begun to squeak / help pls
my right trigger started squeaking is there is anyway to remove the squeaking without disassembling the controller ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
I had the same problem with my controller but it turns out to squeaking is from the spring in the trigger all I did was hold the trigger down and the spring should be exposed and then just move it to the side with a needle and that should fix the problem
这个答案有帮助吗?
得分 3
4条评论:
Which side of the trigger?
完成的
Thanks,this worked!Even though it still seems to be out of place compared to the other trigger the sqeaking is gone.
完成的
@no170846 on the right side of the trigger you should see the spring exposed,it should still be visible a little bit anyway,the left side is covered with plastic anyway
完成的
Thank you so much! I managed to do exactly what you said and worked!
I've had previously put some graphite power on the trigger and it worked for a while, but the squeaking had returned.
完成的
添加一条评论
unfortunately, no
the only way it could be without disassembling is if something is stuck in it.
you should check for liquid/semisolid damage (squeaking probably means food grease, butter, ect. got in the trigger)
https://www.ifixit.com/Guide/DualSense+C...
however, is your controller under warranty?
also many people are complaining of issues with the triggers on this controller, so i would expect a recall of some sort, but i would still try to fix it in case
这个答案有帮助吗?
得分 1
3条评论:
if there are any food grease in the trigger can i clean / remove it without disassembling as well ?
also yes my controller is still under warrenty does it cover the squeaking ?
完成的
you could if you have a small enough item that could clean out the grease
but if that doesn't work, i would go the warranty route
完成的
thank you so much for this comment, all i did was hold down the trigger and blow into it and that seems to have removed whatever was stuck in it and it removed the squeaking.
完成的
添加一条评论
It’s probably the spring that’s the issue. Use some WD-40…works like a charm.
这个答案有帮助吗?
得分 0
2条评论:
It's probably just out of place like Juan's comment said,i would advise trying that first before using WD-40
完成的
I did that and my trigger stopped working altogether.. Use caution when doing that. I took it apart to try to clean the contact point of the pressure sensor but to no avail.
完成的
添加一条评论
blow and hold down trigger on non-mouse click triggers, otherwise, no idea
这个答案有帮助吗?
得分 0
添加一条评论
my problem was with my left trigger i moved the spring and tried to bend it slightly with a knife like the other comment says but i used some super lube it’s a multi purpose synthetic grease and it’s dielectric and now it’s so smooth and i used a little of it for my thumb sticks and they are soooooooo smooth now
这个答案有帮助吗?
得分 0
1条评论:
you can try this by just taking the bumpers off or you can take the two halves apart like i did to make it easier
完成的
添加一条评论
添加你的答案
Jack bale 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 53
过去 30 天: 303
总计 29,396
