跳转到主内容
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
46 个问题 查看全部
Does anyone know for sure if the ipad 7,8 and 9 Use the same port?
Does anyone know for sure if the ipad 7,8 and 9 Use the same charging port? I did a 9th Gen port replacement the other day and realized that it was labeled 7th Gen when I was finished. It did work fine but any time I search online they are sold individually for each model rather then listing compatibility for all 3. Just curious if anyone has any insight on this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
hello rich,
yes you are right. The ports for the ipad 7, 8 and 9 models are the same devices :-) Same as home button connector flex, earphone jack flex, even batterys :-) are the same. Digitizer is the same, and (of course) LCD matrix.
but for seriously, the ipad is a budget device. The differences between models 7, 8, and 9 consist in faster component parameters, which is associated with minor differences in the construction of the logic of the motherboard: for example, the processor power rim has an additional panel in the form of 68 logical pins. Of course, this is related to the different structure of the processor. All other parts (non-logical ones) remain identical. For reasons you can guess - economic.
whole true around the clock only on my blog :-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rich 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 41
总计 367
