跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Dead backlight after replacing key
I replace my wife's C key on her 2017 Macbook Pro, because it was hanging by only one of the retention clips. After replacing all the components of the key, the backlight no longer works. Can this be corrected or has it been permanently damaged?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ouch! Did you poke to deep and hard? There is a thin sheet which holds the tiny LEDs that light up the keyboard. You either hit the LED near the key or you punctured the foil trace which powers them
Replacing it is a sizable job! Here’s the part A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017 A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017
We don’t have a guide to get you down to it, but give this a view 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 all you need to do is get the logic board out as well as the fans and the Antenna bar which can be tricky if you don’t use the correct driver
Maybe it’s best to leave things alone ☹️
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex Brunner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 77
