跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
MacBook external display issues
So, I have a MacBook without a screen. I just got my usb-c adapter today exited to see it function after years and, oh well. Nothing. Just an Apple logo on the external display. I have no idea what’s wrong, I can’t seem to do anything. Also the touchbar doesn’t work so command+F1 will not work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have read a lot of forum posts and I think I have found the issue.
完成的
添加一条评论
1个答案
Where is the internal display? MacBook Pro’s are designed to use the internal display as it’s primary display. You really can’t use it in this way.
Even if the display is not working put it back on and test this again.
这个答案有帮助吗?
得分 0
3条评论:
I have seen a lot of people doing it, so i said to myself that i might try it out. The other display didn't work and a repair was too expensive for me.
完成的
@nicolas36573 - Yes, I’ve seen a few of these so called headless MacBook Pro’s. I’m sorry someone who by chance got it to work without realizing why and then not understand this series SMC will go into CPU Safe Mode when the sensors data is lost.
Basically, the fans ramp up and the CPUs clocking is lowered in an effort to save the system from heat damage.
There’s a bit more here but that is the two major issues which you can’t bypass.
So if you put the display back on fully connected, then using another keyboard and mouse/trackpad connected via USB or Bluetooth, you should be able to use the external display. As long as nothing else is broken.
完成的
Hey, Thank you for the feedback. I have tried SMC reset, and sure enough, it worked like a charm. Booted straight up and now runs smoothly.
完成的
添加一条评论
添加你的答案
Nicolas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 192
