跳转到主内容
加入维修社区 - 创建账户
苹果 AirPods 是于2016年12月发布的无线耳机。
Can I clean AirPods using an ultrasonic cleaner?
Hi! I have had a pair of 1st Gen AirPods for a couple of years and as expected, they got clogged up with ear wax. Using a toothpick doesn't really do the trick as the wax is stuck in the mesh.
My question is: as I already have an ultrasonic cleaner, could I use it to clean them? Alternatively, can I use some cleaning alcohol on the mesh to try to get it out of there (PhoneFixCraft does this on YouTube).
I am afraid the liquid might damage it, but the alternative is buying a new pair, which would really be a waste as they work perfectly otherwise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi
I really wouldn’t do this as ultrasonic cleaners are really good at putting holes in thin things
The speakers in your airpods have a thin plastic diaphragm that helps makes sound
When ultrasonic frequencies hit that chances are they will put holes in it,a way of demonstrating this is by putting a square piece of aluminium/tin foil in and watch what happens
What I would recommend is getting a small brick and a thing pick and cleaning them that way with isopropyl alcohol,that way is much much safer
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrei Covaci 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 157
总计 6,312
