跳转到主内容
Repair guides and support for tablets manufactured by LINSAY.
20 个问题 查看全部
My tablet not charging or coming on
Why is my tablet not charging or coming on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
My best answer would probably limit it to 3 possible causes. 1) Charging port for the device has gone bad, whether it be broken inside and have missing pins, or actually being separated from the board. 2) Maybe a dead battery, but I suspect that if it had a dead battery it would still come online when you plug it in. Or 3) The charger itself has gone bad. This should be easy to test depending on the device. take a multimeter and hook it up to the "-" and "+" and see if the readings match the data panel on the back.. Hope this helps ya.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keaton Graham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 269
