跳转到主内容
The sixth generation of Ford's Falcon line, including the AU, BA and BF series.
4 个问题 查看全部
Where is oil leak from
How to find where oil leaking from engine is
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Use a flashlight to check underneath your car and around your engine – telltale drips might lead you right to the problem. There are several common locations for oil leaks in your car, including: At your oil pan gasket. At your oil filter or drain plug
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rob hutchings 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 123
