跳转到主内容
Device repair and information for HP's line of Pavilion 15" laptop computers.
20 个问题 查看全部
My Space bar is Stuck on one side and is slanted.
I have an HP Pavillion 2018 laptop and my space bar is slanted on one side and the side that is down has a hard time reading space inputs. I was told that maybe it's dust and that's why it's slanted. I was also to use compressed air also. how do I fix the space bar?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
um...you replace the key OR whole KEYBOARD, \_ space bar _/ IS depressed over five hundred thousand times in the life of one keyboard.
COVERED in epithelials, hair grease, food particulate, finger oils, dander, ( cereals and spices beer or aged cheese falling between keys)
AND OCCASIONAL pet walking across the keyboard...
M.A.Bodine
felines also eat plastics.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
What is the full model number of the laptop as shown on the product info label on the bottom of the laptop?
Knowing this will help to find the correct part if there's a broken hinge, clip etc under the spacebar.
Here's a video that gives some idea as to how they're assembled. The clips and hinges on your model may be different so that's why knowing the exact model number will help.
Search online for HP (insert full model number) replacement keys to find suppliers that suit you best.
Here's a supplier just to give an example. Take note of what is said in the Description. They also have installation videos as well.
这个答案有帮助吗?
得分 1
3条评论:
The model is 15- cs0051cl
完成的
@Anthony A.
Here's the same supplier but if you decide to use them verify that it is compatible with your model
完成的
@jayeff alr. thx
完成的
添加一条评论
添加你的答案
Anthony A. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 374
