跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
How to remove the clutch cover
I removed the LCD using the iFixit guide, but it doesn't show how to remove the clutch cover. Any suggestions? I have a A1237 Macbook Air.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Try looking at steps 20 and 21 of the teardown link. I hope they will answer your question.
MacBook Air Models A1237 and A1304 Teardown
这个答案有帮助吗?
得分 2
添加一条评论
I posted a similar question a couple weeks ago just trying to figure out what the part was, and you right, rear clutch assembly. Which is different than the hinge cover. It's not an easy fix, actually, less difficult but reminds me on replacing the front bezel on my first macbook pro.
I broke the system down and pulled the lcd, its fixed on pretty good ... so I just used a plastic pry tool (like you use on iPhones, etc) with the screws removed and popped the new one in.
(now its one of those "*!#$" moments where I should have snapped photos - i do this on other repairs and file for reference)
If I get another on in the shop in the next couple of days I'll try to take some snapshots, or better, some video.
这个答案有帮助吗?
得分 2
添加一条评论
For anyone coming across this still looking to get the “clutch cover" off, have the hinge in the all the way “open" position both sides. Then on the lower lip, push in / up towards the LCD to work it around the hinge pin gently, if needed use a small tool in the open space for a little leverage, they are very fragile. Hope it helps someone!
这个答案有帮助吗?
得分 0
1条评论:
Yeah this is a challenge. Thank you for posting your photos and comments. I've been struggling not to break any of the plastic
完成的
添加一条评论
添加你的答案
lotusblsm17 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 5,686
