跳转到主内容
Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
1 个问题 查看全部
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
这个答案有帮助吗?
得分 2
2条评论:
After testing, it appears to be a dead capacitor. Thank You!
完成的
@Joseph Galaska No problem, hope you get it working.
完成的
添加一条评论
添加你的答案
Joseph Galaska 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 74
总计 526
