The Acer Spin 5 is a mid-range laptop with a 15.6-inch display. The Spin 5’s display can rotate nearly 360 degrees around the base of the computer, which makes it very versatile for various applications. Our research has not indicated any major recurring issues with this device or any manufacturer recalls since its release.
Did you tried replacing the battery? It can be an issue with your laptops logic board or it can be a faulty connector or a battery. Try opening it up and checking on the battery connector’s condition or any corrosion on the motherboard.
