How to replace the volume nob
I broke the volume not on my corsair k70 mk2 and while I had it I found it really useful but I can't find a replacement part online and it is really bugging me because I dont want to have to buy a complete new keyboard
There is a screw under the trim ring on the side of the volume wheel. If you take off all of the keys to see the screws to take off the backplate, there is one that is not easily seen as you need to pry that silver trim ring off the right side and there is the last screw under there. From there, replacement of the wheel is pretty simple.
这个答案有帮助吗?
I simply sprayed with a electronic cleaner foam and blew out with air and wiped off wheel and its solved all my scrolling skipping issues and got it back to excellent accuracy, if the scrolling is functional, but the accuracy is messed up.
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 65
总计 1,805
1条评论
Hello, i'have the same problem, did you find a remplacement wheel ?
Thanks !
由 JcAspes 完成的 分享
