跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
mac installation fails and restarts after selecting disk
I'm trying to do a fresh macOS installation on my 2017 macbook pro but it freezes when the progress bar starts, then "your computer restarted because of a problem" message shows up and restarts. Same happens when I try to restore using time machine. Ps: I have the lcd cable disconnected.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Are you in recovery mode? You should try erasing and re formatting your disk, and then reinstalling macOS.
这个答案有帮助吗?
得分 0
3条评论:
I have done all the above but it still fails. Could it be the usb-c hub I'm using? I tried a different yet similar hub today and it still failed.
完成的
Try changing that… It could also be a thermal issue. Make sure you have the back cover on your Mac; that acts as a heat spreader.
完成的
@ryan39167 - This series doesn’t use the case as a heat spreader/sink. If offers a proper heatsink and fan.
完成的
添加一条评论
@chillin_otb - What happens after you connect the display back in & any other parts, minus the bottom cover. Then with the charger plugged in restart the system and pressing the D key to enter into diagnostics. Are you able to get that far and running diagnostics did you get any errors? If you did tell us what you got.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chillin Otb 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 26
