跳转到主内容
Repair information for the Seagate Expansion HDD external storage device. First available on Amazon in 2015. Model numbers: STEA1000400, STEA2000400, STEA3000400, STEA4000400, STEA5000402.
My HDD doesn't work
My Seagate external hard drive is not working. I hear sounds of working from it.
But, when I connect to devices like computers. Android phone. TV... they don't show any reaction. What should I do to solve this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hi,
Have you tried connecting the HDD using a different, known working, compatible USB cable, you didn't say?
完成的
hi . yes i try it but still not working.i try many of program's too .
完成的
添加一条评论
3个答案
Try to take hdd from cady and connect using SATA cables.
这个答案有帮助吗?
得分 0
3条评论:
i try it with sata cable. but didn't work .
完成的
it's spinning normally without any noises or stopping? It's windows or Linux see the HDD at all ?
完成的
it works but any os can't recognize.
完成的
添加一条评论
I think the carrier logic has a problem, if I remember correctly the drives are a custom design which won’t work directly via a SATA connection.
See if you can find a second carrier unit see if that solves the issue.
这个答案有帮助吗?
得分 0
2条评论:
No, I think there is a problem with a part of the hard drive. I would like to know if anyone knows how to repair an external hard drive And basically, can it be a problem with a part on the external hard drive?
完成的
OK, let’s say there is a drive issue do you have access to a second drive unit to swap out?
The controller part is part of the carrier or if the mechanical park of the drive is failing then you will need to ship the drive to someone who specializes in data recovery. That’s assuming you have something of value you need to recover, warning! This could be expensive and depending on what failed not recoverable.
完成的
添加一条评论
Does the drive appear in device manager if you connect to a computer? If so see if you can format it. I think it’s fat32 but double check.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hossein Abbasei 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 826
