跳转到主内容
加入维修社区 - 创建账户
这是一款由 Saeco 开发并以 Starbucks 品牌重新推出的易用型家用浓缩咖啡机。这款咖啡机非常适合日常饮用浓缩咖啡的用户,且具有出色的做工和产品寿命。
Portafilter - Busted and probably unfixable... need suggestions.
So I bought that little L-spring to fix my portafilter and discovered that a peg seems to be missing to attache the one side.
I tried jerry-rigging it by adding a screw where the missing post is and it didn't power up then pop when drawing a shot.
I've seen suggestions and they're all pretty sketchy.
The newer and disappearing version of portafilter isn't cheap, but seems built cheap.
Does anyone know if the portafilter for the HD8325 (Poemia) units works with ours? It looks like it should and those portafilters are available and cheap: Philips Encompass
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
You know... even if it doesn't work, parts could be scavenged from the look of it: https://101coffeemachines.info/wp-conten...
完成的
Encompass didn't answer my question if the Poemia portafilter is compatible. They only said the part to my unit has been discontinued and is no longer available.
Kind of weird.
I'm seriously considering buying one, trying it, and possibly swapping out pieces because the original was more solid.
Someone needs to test that for compatibility. At $28 it's a good solution.
完成的
I ordered a Poemia part. I paid a few dollars more on Amazon, but returns are easier with them.
I will report back.
完成的
添加一条评论
2个答案
已选择的解决方案
It's a match. Side by side. Original Estro Vapore portafilter and Poemia filter.
About the only difference is that they used a lighter metal. There was a slight change in indentations that prevented me from removing the mechanics from the inside and swapping them.
EDIT: Tried again, and yes, all the internal components can be swapped out. So if you want to restore an original portafilter so you have the solid build, you can buy one of these and swap everything from the plastic round with a gasket, to the internal mechanisms and springs.
这个答案有帮助吗?
得分 0
3条评论:
Since a couple replacement parts cost the same as a whole portafilter, I got my nerve up, gutted my newer portafilter and inserted all the pieces into the metal portion of my old portafilter from the late 90's.
All the springs and mechanisms may be the same, but the new one weighs 6-3/4 oz less because it's made of light (probably cheaper) metal.
And yes, it stays hot longer when brewing. Glad I did this.
完成的
my Estro Vapore has a different portafilter. It is all metal with a metal cube dangling out of the center hole (where the one pictured has the big spring). I either lost a piece when cleaning, or put it together wrong cuz the water comes straight out of the hoke where the bigger screw is, I would love to see the assembly for the version I have , or to find a replacement portafilter.
完成的
@djc44708 My Estro Vapore portafilter is from the 1990's. The replacement portafilter I'm showing is current.
There IS a non-pressurized filter that requires you tamp the grounds correctly. More skill is needed.
It would looks something like this: https://images.espressomakerguide.biz/l-...
The filter I'm showing has a pressure release valve and just attaching it to the machine and pulling the handle to the side is all you need to do.
完成的
添加一条评论
最有帮助的答案
Hi Stan,
No idea on the cross-compatibility issue, but that slot where the spring is supposed to have a post reminded me of something, and I finally remembered what it was. The last time I replaced the toilets in my house, I used the exact type of screw you need to secure the toilet bowl to the flange on the floor. The bolts have thin oval heads, which you'd need in order to slide under the base, then maybe a thin washer on top and the thinnest nut you can find to go on top.
Obviously an actual toilet flange bolt is going to be too big for what you need, but if it was me I'd head to the hardware store and start poking through the drawers for something like that.
I had one other thought as well. If you take that spring at the bend where it's supposed to go onto the retaining post and bend it downward 90 degrees, you could drill a hole just big enough for the wire to go into. Shove the wire into the hole, and then bend the end on the other side of the base plate so it can't pop back out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stan Landers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 584
