跳转到主内容
Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
11 个问题 查看全部
No power to radio, windows, wipers
I have a 1999 dodge caravan sport and it just recently started to have a problem. When I crack the van up it sounds like a small pop sound under the dash and I have no power to the wipers, windows, and radio, and the air then switches to the defrost automatically. However, when I turn the van engine off the accessories then come back to life, but they go back out again when I start the motor.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I immediately suspect a bad ground. Most vehicles have a grounding block that will commonly ground many accessories. It will usually have a metal strap looking cable coming off of it that connected to the motor, trans or frame.
Hopefully someone here can tell you where to find the grounding straps on a 99 caravan. Unfortunately I have no idea.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 16
总计 91
