跳转到主内容
加入维修社区 - 创建账户
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
When I turn my SNES on the screen is purple
The system turns on but my screen instantly turns purple with no other images on it. I’ve throughly cleaned the 62 pin connector (there was no corrosion or rust on it) and the whole motherboard. I am using a third party power supply but everything else is OEM. Anyone have any ideas on what I can test or replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
What type of TV are you using? How are you connecting the SNES to the TV (RCA, Composite)?
完成的
@andrewsawesome I'm using a RCA to HDMI adaptor on my OLED LG. The adaptor works when I use it with my Nintendo 64 and Gamecube.
完成的
@mow79 So to confirm, you are not using the RF modulator? Also, do you have a multimeter?
完成的
@andrewsawesome Correct, I am not using the RF modulator. I do have a multimeter.
完成的
Just for my curiosity, are you loading a game when you turn on the SNES?
Also, assuming you are talking about the NTSC SNES released in '91 the power rating is at 10V at 850 mA. I would try a different power supply to see if that might be the culprit.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
I figured it out, I got a new game to test out to see if my Super Gameboy cartridge wasn't working and it turns out that was the case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex P 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 24
过去 30 天: 42
总计 510
