跳转到主内容
broken pins on Huawei Mate 10 motherboard. Still repairable?
Hi all! I'm trying to revive my old phone by replacing the bloated and dead battery and found out about this issue. I know I can still buy a motherflex cable for mate 10 but the pins on the motherboard itself are broken.
Is it still repairable? Here are some photos
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Luke,
It is possible to replace that connector on the motherboard, but it does require some fine skills in soldering, or microsoldering as it's being called nowadays. Generally it's done with hot air rather than a soldering iron, although once it's off you would generally clean and tin the pads with a fine tip soldering iron.
The part itself is cheap and was surprisingly easy to find; here's an example from AliExpress.
Fpc Connector Huawei Mate 10 Pro Charging
I think this is the right one, but it's hard to count the exact number of pins from your photo; you can probably do a better job with a magnifying glass. There are quite a few that come up if you search for "Huawei Mate 10 FPC connector", so pick the one with the right number of pins.
If the soldering job is out of your comfort zone (like it is mine), you can probably get a local repair shop to do the job fairly cheaply; for them, with the right tools and experience, it should be fairly simple.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! Will definitely find a local repair shop since I'm not comfortable doing the microsoldering by myself.
完成的
添加一条评论
最有帮助的答案
Yes, new connector and ribbon. Hot air station and soldering skills. Not a massive job. If you don’t feel up to it yourself try and find a good repair shop. Some pc repairs will be able to solder a new one on for you too if you have the part.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your help! Will try to find a good repair shop for this.
完成的
添加一条评论
添加你的答案
Luke Sta Ana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 327
