跳转到主内容
蘋果2020年的主流 iPhone 機型,發布於10月23日,搭載6.1吋 OLED 螢幕及12MP 雙鏡頭模組,有著5種顏色。該機型為 iPhone 11的後繼產品。
My face id does not work after replacing the backglass
Recently i have replaced the back glass of my iPhone 12 as far as I know face id should not be affected by it but still it doesn’t work. It did work before the replacement.
Update (02/21/2023)
O have on of those heat tables so i can remove the back glass a bit easier.
when i want to do the face id it says that it is not available
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi furkan,
So what method did you use to remove the back glass? Heat gun? That's the most common way for us home DIY-ers to do it. The downside is that there are a lot of components on the other side of that sheet of metal the glass is mounted on, and it's not at all uncommon for those components to get damaged as a result of the heat used.
By far the safest way to do a glass replacement is to basically gut the phone before starting so you don't get heat damage on any of the components; of course once you've gotten to that point you might as well just buy a replacement housing. The use of a laser to burn off the adhesive is what the professional repair shops use, as it doesn't transfer much heat to the inside of the phone, but that's not something most of us have access to.
Can you be a bit more specific on what isn't working with your Face ID? Is it not available, or it's telling you to move a little closer/further away, or what?
这个答案有帮助吗?
得分 2
3条评论:
I am having the same issue, because I did a back glass on a 13 mini however now the phone says Position your face within the frame.
完成的
It’s not available
完成的
@miskaylaxjames Generally that particular error is related to the front camera. Did you also do a back glass replacement? It's possible you overheated the flex cable on the selfie camera causing damage. Does the camera work otherwise?
完成的
添加一条评论
Open the phone and remove the front camera, Face ID module and check you haven’t damaged the ribbons.
这个答案有帮助吗?
得分 1
添加一条评论
Mine too is showing Face ID is not available
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
furkan F. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 733
