跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
718 个问题 查看全部
Error Code: 2002-4687 - what this stands for?
Hi, my console from this morning started to display the error 2002-4687. This requires restart of console.
But that did not help. I've tried to remove SD card and game cartridge, and try again with same result. The error also was showed in the Factory Reset menu (after press and hold power and both volume buttons) but not always. I've managed to select factory reset, but the process is stuck on "Restoring factory settings..." and I just gave up after 2h of that.
Do you know the exact description of 2002-4687? For what I suspect this rather has something to do with the internal console memory.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Ok, It's been a while, but for history records I will post here on how I solve this problem. This requires some soldering skills, because we need to install mod-chip into our console to be able to read production info data from the console and THEN rebuild console memory. I wont post here the details of how to mod console, but this is required step that console must be mod - you can remove mod after the fix, or you can leave it and just not use it as I did.
So I did this,
  1. I bought used emmc memory for Nintendo Switch V2. V2 has memory that is attached via slot and can be replaced without soldering it to the motherboard.
  2. I've bought rp2040 mod chip on Chinese page (starts with A) and installed it on my console. Process wasn't so hard, just had to use a lot of flux. You can also find tutorials on yt on how to do it.
  3. I've followed this guide https://youtu.be/kN7jWR5o10g on how to rebuild emmc nand memory using product info from my console.
Sadly there was no possibility to recover game save data, I've even asked also the author of this tutorial and he answered that this is not possible.
这个答案有帮助吗?
得分 1
添加一条评论
on the Nintendo customer support site, it says it is a issue with the microSD card
do you have another microSD card made for/supports the switch? (usually have a power up from Mario games on them if they are made for Nintendo consoles) that you could test if my theory is correct?
这个答案有帮助吗?
得分 0
3条评论:
There are similar ones but not this error code, but you are right in that part - all of them are regarding the corrupted memory. This exact code is not listed on Nintendo code. I've reached their support but all what they did is they told me to check the sd card data corruption from Nintendo menu, but the problem is I cannot enter the menu, because error is shown just after the Nintendo Switch logo when console boots up. The same result is with, or without SD card inserted. After I explained them that this is impossible, they requested video with the proof ;)
From my perspective it seems like corrupted internal eMMC storage, I've took apart the console, and unplug the memory, but console won't boot up without that ... I've took the long shot and ordered a spare emmc memory part.
完成的
that's actually what i would have recommended you do, so your in the right direction, just be careful and don't break any connectors bc its a nightmare to try to fix
完成的
@timtomissus thank you ;)
btw I've found some site with I guess custom firmwares for Nintendo Switch... the post is dated (2019) but the error code the guy have is very similar to mine, and the behavior is the same:
https://gbatemp.net/threads/bricked-swit...
What bothers me is that the guy clearly was messing with the firmware, what I did I was just using my switch - played "divinity original sin 2", then left switch on shelf, and after a day tries to unlock console, but just after I've unlocked - bam - the error message.
完成的
添加一条评论
添加你的答案
Johnny Thornal 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 88
总计 1,768
