跳转到主内容
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 个问题 查看全部
Why won't my new WD SSD boot up? Cable is good as is the HD
I replaced the HD with an SSD from Western Digital. It will not but up the utility, only a folder with a question mark. I know the HD is good because it lights and the Sata cable is good because it will boot up the old hard drive. It also will boot from a USB disc or the internet. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your machine uses SATA II. Did you buy an SATA 3 drive? What drive did you buy?
这个答案有帮助吗?
得分 1
1条评论:
SATA is backwards compatible, newer devices just run at the older speed
完成的
添加一条评论
添加你的答案
Roland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 33
