跳转到主内容
The Dell Inspiron 7586 2-in-1 is a 15.6-inch laptop that features a 360-degree flip design that allows the laptop to fold over into a tablet.
2 个问题 查看全部
Why is my laptop not charging or turning on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rockhard ,
Check that the charger is supplying 19.5V DC at the plug on the end of its output cable.
If the charger is OK, then it may be a problem with the DC-In jack in the laptop.
Here's a video that shows how to change the DC-In jack. It is helpful as it shows how to access the jack so that you can test whether it is faulty or not.
If the jack is faulty i.e. no voltage when measuring between the red and black wires on the internal cable plug connected to the jack - or with the power disconnected, using an Ohmmeter to test the continuity of the +ve and -ve wires from the jack input to the jack output, search online for 0ND3N8 to find suppliers that suit you best.
If the jack is OK then there's a problem on the motherboard and the motherboard schematics would be needed to find out where it is. What is the motherboard's board number, as printed on the board itself?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 124
