跳转到主内容
Released in 2014, identified by 11.6 inch screen, 2-in-1 convertible touchscreen laptop. Model number 11t-n000.
23 个问题 查看全部
laptop internet also disconnect automatically after few minutes
My laptop internet also disconnect automatically after few minutes. I am facing this issue from morning i did all those above steps, my driver are also upto date. To get reconnect i had to turn on airplane mode of my laptop and then turn off then i need to connect the wifi manually. any one guide on this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My problem is fixed. I think its due to some temp file virus or bug because i used ccleaner to make my pc optimized but this also fixed the wifi problem don't know how but it got fix.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @yousaf0980
Please confirm the make and model number of the laptop.
Does the WiFi turn off or does it just simply disconnect from the internet?
If it just disconnects, try using the laptop's WiFi as close as possible to your home (or work) network router i.e. <20cm, and check if the connection remains stable.
If it does it may be an antenna problem in the laptop.
这个答案有帮助吗?
得分 2
4条评论:
HP laptops are infamous for poor wifi range and performance, i've had several that can't even get a connection from across the room. Definitely a good idea to try to get as close as you can to the router.
完成的
It was working fine from yesterday it is showing problem. My other home laptop working fine. I think it is issue in windows.
完成的
@yousaf0980
Did you try what I suggested, you never said?
if it works OK if you try this, then knowing the exact model number will help to find the service manual to make for an easier repair.
完成的
i don't know what happened but it is fixed now itself
:P i just used ccleaner once after that don't know what it fix but problem is gone now.
完成的
添加一条评论
添加你的答案
Usaf Hori 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 41
