跳转到主内容
加入维修社区 - 创建账户
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz 双核 i5 处理器。于 2017 年 6 月发布。
No display and no chime.
2017 iMac with display issues and no chime at boot.
1st 3 LED’s light up but the 4th LED will not light up and external display does not work either.
If the cables for the monitor are attached fan moves slowly. If I disconnect the cables and turn it on fan blows at full speed.
Is this a display issue or a logic board issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The fan is likely working correctly here. SMC controls the fan based on thermal sensors, so when you disconnected the display cable SMC went into CPU Safe Mode which will push the fans RPM.
With that said this series uses the integrated Intel graphics engine within the CPU. Sadly that part of the package failed. You need a new logic board.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much for the reply!
由完成的 分享
添加一条评论
添加你的答案
Infinus 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 40
总计 368
