Black vertical lines on MacBook display
These lines appear at random, and this text also appears sometimes when restarting... Any ideas what the problem might be?
So you want to get your MacBook Pro out of jail! Sadly, you’ll need to pay the jailer to get your system out.
Your issue is a scanning issue within the displays T-CON logic. This is likely not repairable as it will require deeper skills to locate the capacitor which is failing. I would just replace the display assembly as it’s quicker MacBook Pro 15" Retina (Touch Bar, 2018-2019) Display Assembly here’s the guide 2018 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
这个答案有帮助吗?
@danj Thanks! So just to confirm, are you 100% sure that that is the problem? I just don't want to buy it if it's not the part I need lol
@steury2004 - I’ve seen this before. But to prove it connect an external display which would show a clean image when the internal is messed up.
@danj Good idea, thanks!
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 91
