跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Help! iPhone stuck in boot loop with weird shadowing on screen
im planning on replacing the display, just need to find a part with a digitizer and lcd with all the small parts
it only turns on when its plugged in as shown in the video, and has a weird shadowy affect after it turns itself off.
anyone know what to do?
ive tried putting in in dfu mode while its doing this,hard resetting also, and it doesn't help
is this also a display issue/recovery issue or is it something else?
I GOT TO GO INTO RECOVERY MODEEEEE
okay but is it compatible with the newest itunes update?
what do i need to do to actually recover this phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
are you concerned about data on the phone?
if not, then i'd recommend downloading 3utools and installing it on your PC. put the phone into DFU mode (you will need to google how to do this for your model), connect it to your PC and execute a anti-recovery Flash.
this will install the latest firmware and IOS for your phone.
this usually works for me when i get bootlooping phones to evaluate - but only if the data is expendable.
这个答案有帮助吗?
得分 1
3条评论:
@beekerc
is there a version for mac?
also i don't mind the data, i bought this phone off ebay to repair
完成的
also the phone turns off before i can put in dfu i only can barely get recovery mode to work in time before it shuts off it only stays on for about 10 seconds before turning off:(
完成的
@timtomissus
no. 3utools is for pc only, sorry
完成的
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 265
