跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
OWC Aura Pro SSD not recognized
Recently purchased Aura Pro SSD drive. I cannot get my Macbook air to recognize it. Im running MacOS Monetery 12.6.3. When i install the drive, the computer will not boot. When put the drive in the external enclosure it does not show up in diskutil at all. I have tried recovery mode. still not visible. Don't know how to overcome this issue. OWC has provided zero support.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure you have the correct OWC drive. This is what you should be working with OWC Aura Pro X2 SSD
If it is let’s see if we work with an older release works, then upgrade it from there.
To start off we need to create a bootable USB thumb drive a 32GB drive is all you need. Using your Mac reformat it to GUID HFS+ And then copy from here the OS installer file How to download macOS I would jump back to macOS High Sierra (10.13) here. Follow this guide to convert the installer into a bootable version Create a bootable installer for macOS?
Now using the bootable installer see if you can bootup with it and can gain access to the OWC drive using Disk Utility.
Replace or upgrade the PCIe solid-state drive in a variety of Macs.图片
产品
OWC Aura Pro X2 SSD
$199.99
这个答案有帮助吗?
得分 0
5条评论:
I did suggested in the post. unfortunately the drive is still not visible. Is not recognized at at all
完成的
@John De Visser - Were did you buy the drive? I would return it or contact OWC to see what they say.
完成的
Drive was purchased directly from OWC. They are not being helpful or responsive in dealing with the problem. I am now pretty sure the drive is dead.
完成的
@John De Visser - Just return it and get your money, I’m surprised but it’s been awhile I have bought an OWC drive (mostly I install Apple units).
完成的
OWC is not responding on the return request. Six weeks now and no response from them. Very disappointing.
完成的
添加一条评论
添加你的答案
John De Visser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 163
