跳转到主内容
作为任天堂 Game Boy Advance 的一款升级产品,Game Boy Advance SP 于 2004 年 3 月 23 日在北美地区发布,它采用了方形机身结构和翻盖式设计。
L Button not working
The L button not working at all, tried replacing the button with the springs but didn't fix the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Are you getting continuity through the switch? If so, you will need to trace deeper through the circuit.
完成的
添加一条评论
1个答案
Hello! This may be caused by a dirty button on the motherboard. On the SP, the button switches get dirty and the rubber piece on the button won’t make contact. I would take 90% or higher isopropyl alcohol and clean the switch on the motherboard and see if it works. Good luck!
这个答案有帮助吗?
得分 0
1条评论:
Never use pure isopropyl alcohol to clean switches. They leave a white film and make the problem worse than before. If you're going down that path, use proper Contact Cleaner. It's not much more expensive than isopropyl alcohol. Original poster has already replaced the switch, which didn't fix the problem.
完成的
添加一条评论
添加你的答案
MESUT OZIL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 393
