跳转到主内容
How to remove keys off of a MacBook air
i want to make sure before removing any keys by just pulling them off that there isn't any adhesive or anything i could damage by just pulling the keys off of the key board
the reason that im removing the keys is because of a large amount sugar got under the keys on the left side of the keyboard
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Why are you removing the KeyCaps?
这个答案有帮助吗?
得分 1
6条评论:
I'm removing them to clean out a large amount of sugar that was spilled on the keyboard and got under the keys :C
完成的
@timtomissus Without being able to give a proper method to remove the keycaps efficiently, I can say that they are only held on by tiny plastic clips on butterfly hinges. These clips break very often, so be gentle.
完成的
@cashewclay can you still put the key back on if the clip breaks?
完成的
@timtomissus Each key cap has two clips and two tabs, as pictured quite well here: https://www.laptop-parts.com/blog/MacBoo...
Check out where the clips are before prying, just so you know exactly where to pry and minimize the chance of breaking clips.
Edit: my partner just informed me that you may have scissor switches, not butterfly keys.
完成的
@cashewclay would it be the same protocol if the mac had scissor switches?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 158
