为什么msi gt70 ms-1763的摄像头不工作?
在电脑设置里面看不见摄像头程序,也没有发现摄像头工作 。
外置摄像头就可以使用,但总不能外挂一个吊瓶啊。
这个时候你可以尝试打开电脑主板,检查摄像头的连接线是否完好,早起的笔记本电脑会在使用过程中和年限长久造成受潮,或许是某一路升压电路损坏,所以可以先尝试清理灰尘
这个答案有帮助吗?
Fn+F6. Different notebooks are different. You can generally look at the camera icon above, mine is F6)
这个答案有帮助吗?
If the camera of your MSI GT70 MS-1763 laptop is malfunctioning and you cannot locate its program within its settings, there may be several possible causes:
Driver Issues: Your camera driver could be outdated or missing. Check the Device Manager on your computer to identify if there are any issues with it, then update or reinstall using either manufacturer website or disc installation method.
Camera Settings: It could be that the camera has been disabled in your system settings. Check its BIOS or UEFI settings of your laptop and make sure the camera is enabled there; additionally, double check that its access has not been blocked by privacy settings on your operating system.
Hardware Malfunction: There could be an issue with the camera itself. To check, connect an external USB camera to your laptop and see if that works properly; if so, this suggests there may be a hardware problem inbuilt into its hardware.
Software Conflicts: On occasion, other software or applications may interfere with camera functionality. Try closing any unnecessary programs or performing a clean boot to see if your camera begins functioning again.
Regardless, if these steps don't resolve your problem, it may be necessary to seek further assistance from MSI support or a technician. They may be able to offer more accurate guidance in diagnosing the specific model of your laptop and troubleshoot more precisely.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 91
