跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Doesn't stay at temperature long enough.
At first I noticed while steaming milk, the temperature ready light would turn off before I was done. To get around it I just turned off the steam, waited for it to get up to temperature again, and then resume.
This issue got worse over time.
Now when I brew shots the ready light turns off before the shots are even finished. I had stopped using this unit for years as a result.
Working on a different issue today I either broke and lost or suddenly discovered that the L-spring is missing from the portafilter.
Before I order a replacement spring I was hoping to have a plan for the temperature issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
9条评论:
Reviewed sidebar questions? There may be deposits clogging/blocking water flow in the heating system requiring periodic demineralizing to dissolve them.
完成的
@notbroken I did descale, and I'm waiting for the replacement spring to re-test.
I did see someone respond to a similar question saying that the ready light turning off is normal when drawing shots. I just don't remember that happening before.
完成的
@vauweh this should be right up your alley of expertise. @stanl do you have a model number or any other identifier for this machine?
完成的
It's actually an Estro Vapore from back when Starbucks first started selling Saeco machines, but before they started rebranding them as Baristas.
完成的
What year was the unit built? Issue sounds like electrolytic capacitors in / near the temperature sensor.
完成的
显示更多的4条评论
添加一条评论
1个答案
Hmmm. Difficult to say... I would look for the thermoswitches located on top of the boiler. There is a guide for a quite similar Saeco. Hope it works!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stan Landers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 104
