跳转到主内容
加入维修社区 - 创建账户
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
How can I fix NFC?
Hi!
I think the NFC of my phone is broken : I use it for Apple Pay and to check my glucose (freestyle libre sensor) and it doesn't work for two days …
I have some questions :
- Is there something else to check or to change except the antenna?
- Where can I find a repair guide to do it?
Thanks+++
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
What troubleshooting steps have you followed so far? Have you attempted to power cycle the device?
完成的
添加一条评论
1个答案
Hello Camcam,
the NFC loop is built identically to the model 8. The important thing is why it stopped working. Immediately before noticing that NFC is not working, did your phone have a fall or similar incident? All this, from the point of view of diagnostics, is important and speeds up the whole process.
The antenna problem never occurs by itself. It is usually related to a fall or wather damage. In fact, all you can do (assuming you have experience with a screwdriver) is to remove the screen and check the continuity of the antenna line from the motherboard to the internal antenna at the top of the housing. In case of an incorrect reading, you can replace the 1-st step antenna. The cost is about $2-5 if you decide to do it yourself. On the other hand, you can test ApplePay in store when paying before and after factory resetting your phone. Sometimes it happens that NFC communication hangs the entire subsystem due to compatibility problems with various devices in this technology. The third and final option is to find a good repair shop where the technician "took his teeth" (or "ate his teeth" - people say that in my location) on repairing the motherboard of Apple devices. You're sure to find a few of these places depending on your location.
这个答案有帮助吗?
得分 0
2条评论:
My iPhone SE is having the same issue, is there a picture anywhere of the NFC antenna and what contacts to check?
完成的
I'm sure you'll find one somewhere online.
完成的
添加一条评论
添加你的答案
Camcam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 45
总计 3,928
