跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
How to fix screen display
why is my screen black but video shows on external display
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi John,
The situation you find yourself in happens when the LCD display hardware fails but the computer's graphics chip is fine. In that case the video signals are coming out of the GPU, but the internal display cannot show a picture while the external circuitry is fine.
If you put a flashlight up against the screen in a darkened room and can make out an image, that indicates the backlight has failed. A backlight problem could be caused by a problem on the motherboard, the display cable or the backlight itself.
With no picture, the prospects darken. While it could be a cable issue, generally the solution is to replace the display. Unfortunately Apple has basically made their displays unrepairable; you cannot open it up and replace just the LCD independently of the touchscreen and/or the rear case, so the only way to fix it is to replace the whole assembly. Here's an iFixit guide showing you how to do that.
MacBook Pro 13" Unibody Mid 2012 Display Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 2
1条评论:
@dadibrokeit - the unibody’s can be checked by placing the light onto the lids Apple logo which offers a better direction of illumination.
Often the logic board LVDS connector gets wet causing it to short out burning the fuse.
完成的
添加一条评论
添加你的答案
johnrpotts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 62
