跳转到主内容
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
iMac Pro Front Camera Showing a Green Screen
My front facing camera will only display a green screen. I have allowed all permissions, unplugged and held down the power button to have a hard restart, and tried different apps and still the camera only displays a green screen. I did an apple hardware test and it said nothing was wrong. Trying to see if there is a how-to on replacing the camera and or any other tips on how to get it working. Software: Venture 13.2 (22D49)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The Apple diagnostics won’t check the discrete camera elements in this case the actual photo detector (CCD).
Did you have the system opened at any point? Is possible the camera unit it’s self got damaged.
I would bring it into an Apple Store and make sure to say to them you only want someone who has been trained on this system to work on it as I’ve heard some repairs of less skilled folks talking on this much harder and expensive system.
I’ll warn you they may just replace the display assembly as the camera is part of it. Try to get it covered under extended warranty if you can. Otherwise you may just want to go with an add-on camera as that would be cheaper!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jeff Jenkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 144
