跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
Is possible to upgrade build in fan to a Noctua one?
My second hand Thunderbolt Display easily getting hot, I can't sure is the fan works or not.(But when the environment is quite, I can heard "bo bo bo" sounds.) Can I replace the fan which has higher RPM with same voltage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sorry Apple uses a custom fan unit. It’s likely the fan is either damaged (out of balance) or loaded up with junk.
Given the age I would start off just cleaning out the dust and debris that’s collected inside. I’ve found stapes and small scraps o paper mess up the fans in system
I find a small soft paint brush and a can of can’d air will do the job!
Here’s one source for the needed fan 27" Thunderbolt Display Fan - Apple P/N 922-9936
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
imjeremysome 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 132
