跳转到主内容
加入维修社区 - 创建账户
这是第三代 Apple iPad 4G 版本的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储空间可选。于 2012 年 3 月发布。可通过型号 A1430 (GSM, AT&T) 或 A1403 (CDMA, Verizon) 进行识别。维修时需要使用热风并小心撬开。
Ipad 3 distorted crackling static noise when trying to play ANY sound.
Ok so I got an Ipad 3 3g (A1430) for repair I changed the battery and the speaker because it wouldn't make any noise when trying youtube or notification sounds, I was testing all new components, the battery its ok but the speaker would only play static while trying any type of sound, I recorded how it sounds and have the video here: https://www.youtube.com/shorts/2fLYcFgrG...
I already returned the new speaker but I'm wondering if it was a bad replacement or is it something else on the logic board.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Visually inspect the socket on the logic board and look for discoloration or bends on any of the pins. From your description, the speaker is receiving power properly, so the problem is improper data transfer at either a pin on the connector, or in the speaker wire itself. A new speaker will certainly confirm the issue. A new logic board is always an option, but may cause home button pairing issues.
Replace a logic board compatible with the 3rd generation 4G iPad tablet. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
iPad 3 4G Logic Board
$31.99
这个答案有帮助吗?
得分 1
1条评论:
The iPad 3 doesn’t have Touch ID so it won’t cause any issue.
由完成的
添加一条评论
添加你的答案
PsiBot 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 21
总计 403
