跳转到主内容
加入维修社区 - 创建账户
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
How can I fix this?
I have been in the process of replacing my mother board and as I was following the instructions to remove one in reverse so that I could put the new one in, a small cable connector popped off.
I believe it’s for the battery and logic board connection. And it was on the battery side. Is there anyway to fix it? Nothing seems to be broken it just popped off.
Attached are photos. Please help I am a student and need a computer. Thank you in advance
Here are the new pictures that were requested.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It looks like you lifted the battery side connector off the logic board. Can you take a tighter picture of the logic board and the back side of the connector. You likely need to use some strong lighting to get a good picture.
这个答案有帮助吗?
得分 0
2条评论:
I just added the new photos to the original post :).
完成的
@Kealan Sucher - This might be salvageable! Do you have access to a hot air rework station? That’s should be able to remount the connector. You will need to protect the area with Polyimide tape so you don’t over heat things.
完成的
添加一条评论
That's the port to the battery data cable connecting to the battery board. Unfortunately, the battery board is permanently connected to the battery. So, if you aren't able to solder the port back onto the battery board, you'll need to replace the whole battery. There may be an easier way to repair the connections between the battery board and the port that broke off, but I can't recommend any to a DIYer.
Here's the replacement battery, which shows the battery board with the port (for reference).
产品
MacBook Pro 13" Retina (A1989, A2251) Battery
$119.99
这个答案有帮助吗?
得分 0
2条评论:
If you are interested in fixing the connector yourself before buying a new battery, try securing the port to the solder points in the exact same position it originally was in. Maybe tape will do the job, or maybe glue, but it needs to be secure enough so it never moves under normal use. Another method to try is to solder it back together. Use protection for your hands before applying heat and don't let the battery get hot. Apply some solder flux to the connections on the battery board, get the board really hot to where the solder is soft, and press the port exactly into position.
These ideas were inspired by this post:
ZIF connector is broken, is there a way to replace it?
完成的
Thank you very much :)
完成的
添加一条评论
添加你的答案
Kealan Sucher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 349
