No its all good one side no sound
M20 one side speaker not working....
Hi
Let’s check to see what the problem is!
Use this guide to remove the ear pads and let’s see if we can see our problem
Audio Technica ATH-M50 Ear pads Replacement
Once the ear pads have been removed remove the screws that secure the speaker in place (don’t let anything touch the speaker itself though)
Once the screws are removed carefully lift the driver out of the housing and see if there are any loose cables
If there are lost cables found you can resolder them back onto their own pads
If there aren’t any loose cables you will need to test for continuity with a multimeter
With both earpads remove check to see if you get a beep or a reading on a multimeter by probing on the pads on the other side of the headphones speaker(silver blobs or solder pads)
Put one prob on one coloured wire and on the other speaker put it on the same coloured wire on the other side
If you don’t get a beep or a reading there is a break in the cable
I would also check the AUX jack as well,check the wire all the way back to the plug
If you are getting a reading or a beep in all the place you should have them you most likely have a faulty speaker/driver and will need to replace it
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 42
总计 279
