跳转到主内容
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
20 个问题 查看全部
cover and USB and bluetooth unfonctional
Hello,
since one week, keypads cover, usb and bluetooth are unfunctional. I try to reboot, and reinstall all driver unsuccessfully. Usb is marked as error type 10. Do you know if there is a controler in common with these 3 components ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Has the data on this device been backed up?
完成的
添加一条评论
1个答案
yes I back up all data
这个答案有帮助吗?
得分 0
2条评论:
Go to https://www.microsoft.com/en-us/download... on the Surface Pro 6, then open and execute the downloaded MSI file. Let me know if the USB etc. is still not working.
完成的
yes I already exectue the MSI, I also re-install windows 10, it change nothing.
this problem is well known, but nobody found a solution:
https://answers.microsoft.com/en-us/surf...
完成的
添加一条评论
添加你的答案
tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 75
