跳转到主内容
Can't update to Ventura 13.2
I may have deleted a needed system file in December; I now get a "current device configuration and target is invalid for install in the current state..." when attempting to update. Do I need to reinstall Ventura in recovery mode, or is there an easier/quicker fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You can try and process the update in Safe Mode. Sometimes this helps process updates that will not process otherwise. You can also try repairing your startup disk.
What makes you think you deleted a needed system file?
Mac OS X图片
指南
How to Run First Aid with Disk Utility
难度:
简单
15 minutes
Mac OS X图片
指南
How to Boot a Mac Into Safe Mode
难度:
非常容易
5 minutes
这个答案有帮助吗?
得分 1
1条评论:
Already did first aid on the startup disk and the other volumes too, no problems found. Have already tried Safe Boot and still couldn't do OS update. I was trying to get rid of some really old temp files that showed up somehow, 2009, from my OLD Mac, and deleted some sort of var/temp folder, then an alias folder was created and now I can't find it. Guess I'll just have to reinstall Ventura in Recovery mode and hope that fixes the update problem. If you have any other suggestions please share. Thanks for your quick reply!
完成的
添加一条评论
添加你的答案
mercyanimals 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 458
